Hemirunner
Looking for a 70 Rallye Gauge Flasher switch. This switch is the one with two mounting screws on the same side of the switch. PM me. Thanks.
Mike.
Mike.
I have one $38 shipped to you.. I will post pics in a minute. Chrome rocker has bubbles on the side...Looking for a 70 Rallye Gauge Flasher switch. This switch is the one with two mounting screws on the same side of the switch. PM me. Thanks.
Mike.
That’s the one I’m looking for. I’m putting it in a 70 to use for the overdrive.I have one $38 shipped to you.. I will post pics in a minute. Chrome rocker has bubbles on the side...
I re-read it and I was right as far as what you were looking for.. It's yours if you want it...PM meThat’s the one I’m looking for. I’m putting it in a 70 to use for the overdrive.
Your inbox is fullI re-read it and I was right as far as what you were looking for.. It's yours if you want it...PM me
Made some room...Your inbox is full
I thought about the same kind of set-up on my Charger, using the Edelbrock tablet from the Pro-Flo 4... I would only need a Oil pressure and fuel gauge.
The brake warning light will now be a green indicator to tell me the OD is engaged.I thought about the same kind of set-up on my Charger, using the Edelbrock tablet from the Pro-Flo 4... I would only need a Oil pressure and fuel gauge.
That’s a great use of it as well. My digital dash has one incorporated into it.With the Dakota digital, I can use the T/S lights and brake warning for something else, might turn the brake warning into a Shift light..
