Do it yourself. Go to harbor freight get some plastic 10-15 clamps. Get some adheasive and a chalk line. Scratch up the top of your car w/60 grit n wipe it off (the glue won’t stick good to the paint). Chalk the center of the car front to back and the vinyl front to back, match up centers, adjust seams on pillars to position you want. Clamp it down from n back. Peel 1 side up to the line and glue 10 inches of the top down or however much you feel you can do. Repeat til done with 1st side, don’t squeegeeing it down, it will stretch. Clamp it down to hold it and Repeat other side. I’m sure others have better tricks to do it, but I’ve only done this once but was pretty easy and mine still looks good. Oh you will have to trim it obviously
