Only turn left...
Only turn left...
Always has to be a comedian in the bunch .Only turn left...
What do you mean change the steering lock?change the steering lock or put on a big tire that hits first
I did discover that if I put another castle nut on the end of the strut rod, that will bump before the link hits the pan. Thing is that there is only 2 or 3 threads left. Maybe some blue loctite on first?I would look over the right side tie rod end /lower control arm area and find a spot to tac in a piece for a steering stop.
I would like to just smack it a few times with a hammer. Don't think it would take much, but like I said I am not sure where all the baffles are inside.I don't see how you could modify the pan without removing it.
Everything is brand new. Moroso solid mounts.Engine mounts?
These strut rods are the heavy duty ones that Mancini sells. There are no castle nuts or cotter pins on them. The threaded end is 9/16 - 18.Can you take a 1/16 or 1/8th off the 1st nuts castles notchs and still have a good notch for the cotter pin ? That may get you a couple 3 more threads and loctite.
