Kevin Bisgrove
Can anyone help?
Wow talk about an early build, Aug 8th, '68?
P6C- blue and white bucket seat interior. B7- blue upper door frame paint. 1W- white vinyl top. 6W- white longitudinal stripe. 917- last 3 digits of the engine assembly part number. 595- last 3 digits of rear end assembly-3.23 8 3/4 sure grip with 11 inch brakes. 093- trans part number 2892093. That number should be stamped into trans on the driver's side just above the pan. P31- power windows. The two numbers on the top left are gate and sequence numbers for plant use. The last 8 digits of your V.I.N are on the top right.
69 Lynch Road did not put the V in front of the top or stripe code.Was I partially or mostly correct? For a vinyl top I thought it was V then whatever it was?
What would the white longitudinal stripe like like?P6C- blue and white bucket seat interior. B7- blue upper door frame paint. 1W- white vinyl top. 6W- white longitudinal stripe. 917- last 3 digits of the engine assembly part number. 595- last 3 digits of rear end assembly-3.23 8 3/4 sure grip with 11 inch brakes. 093- trans part number 2892093. That number should be stamped into trans on the driver's side just above the pan. P31- power windows. The two numbers on the top left are gate and sequence numbers for plant use. The last 8 digits of your V.I.N are on the top right.
It helps a lot thank you.Lots of data presented in this thread. Some correct, some not. Fender tag summary below.
Line 1
RS23 - See VIN Definition above
E86 - 440 CID 4 Barrel V8 High Performance 375 HP
D32 - Heavy Duty Automatic Transmission
808 - Scheduled Production Date (SPD)
B03546 - Vehicle Order Number (VON) Canadian designation (B)
Line 2
B5 - Top Color: Blue Fire Metallic
B5 - Body Color: Blue Fire Metallic
P6C - Premium Bucket Seats, White with Blue Carpet
B7 - Upper Door Frame Color: Jamaica Blue Poly
Line 3
1W - Vinyl Top: White
6W - Transverse Stripe (Wide): White
Line 4
Blank no codes
Line 5
917 - 440 4BBL, automatic transmission, heater, 375hp, Orange
595 - 3.23 s/g, 8 3/4, 11" rear & front drums
093 - 727 Automatic Transmission, 383-4BBL & 440 HP engines
P31 - Power Windows
Line 6
08 - Gate Number
147 - 47th Car through this gate this day
100340 - 340th Car to enter the body in white portion of the assembly plant this year
9 - 1969 Model Year
A - Assembly Plant Lynch Road Detroit MI
100844 - Sequence number (VIN), 844th VIN assigned this model year
Based upon the tag data, this car was built on the first day of production (8/6). Thank you for sharing. I hope the above helps you.
D
Great thank you. I thought it may have been.6W is the thin white line above the black. I have one also,
Big D, thats a road runner, isnt the GTX stripe different?
All good man! Great information and highly appreciated.You are correct. Thank you for pointing out my error. This is what happens when a Dodge guy comments on a Plymouth . I have removed the V6W Roadrunner picture to prevent confusion. I see 3 codes for the Sport Stripe on the GTX. V6W, V6R, or V68 (Delete). Yes, it is the single wide below the trim line on the GTX.
Sorry for the confusion....
D
