Not hard to do. I used a product called GOOP to glue mine in. Also found that a strip of 1/4" plywood slipped into the freshly assembled run held the shape while it set up.Unless things have changed in the past 2-3 years, no one offers a kit or direct install for that Joe has a roll of the run that you have to install ( glue)as per his directions ( not hard) and then trim off the edges ( it is too wide).................MO
