- 8:53 AM
- Mar 10, 2010
- Hanover, Pennslyvania
So I finally got some time to take off the fuel pump and opened it up (first time at this). Only thing I forgot was to take a reference photo for the orientation, shouldn't be to hard to figure out. Anyway I'm assuming this plunger seal looks worn enough so that it won't function properly. It's not separated or torn on the other side. There is a little bit of the small particals in the bottom section, but I don't think it's enough to mess it up. Nothing plugged. In the bottom seal you can see some of the grainy partical laying on it. I don't think this is a filter, at least not based on a couple of the rebuild kits I looked up.
View attachment 957236 View attachment 957237 View attachment 957241 View attachment 957242
https://www.forbbodiesonly.com/moparforum/threads/mechanical-fuel-pump-101.194336/
