i may have mixed up pics but they are nos blocks.freeze plugs and paint to keep from rusting makes them used???????It's NOT 'nos'. Either is your other block.
NOS= NEW old stock.
Never used or altered from it's as-purchased state. They both have had freeze plugs installed and at least one spray job. Same bore picture in both ads..
OP responded back but still won't clarify, on this or his other thread, what's going on with the pictures??
because it says hp on pad that why.and freeze plugs is altering something?i guess u have trouble keeping anti freeze in your engine then.and yes,i still conside it nos.even with your so called altering with paint and feeze plugs.i dont take it personal,we have diff opinion of nos i guessNot used and NOS are two different things here...do you consider an altered part still NOS?
Look don't take it personal, I'm just trying to get you to be accurate in your descriptions.
If you've mixed up the pics, that's fine, honest mistake, just fix it please...and maybe you could clear up why you're advertising your 440 service block as HP.
Just looking for clarity, that's all.
both the 426 and 440 have hp on padNot used and NOS are two different things here...do you consider an altered part still NOS?
so i guess crossram intake not nos either as it has carbs installedNot used and NOS are two different things here...do you consider an altered part still NOS?
