Yeahrightgreer
Finally starting the assembly on my 512” w/ a Proform 950 Carb and have yet to plan out a fuel system. Mostly looking for tips and advice. This is a full on street car which will see a lot of miles idling, cruising or street racing on a Saturday night.
I know there are some good reasons to just go to a fully electric system - but I like the idea of a high volume mechanical pump to live on the street; and a electric pump on a switch that I won’t have to constantly listen to. Additionally - I would like to take the car on long drives and not have to worry about being able to walk in any store and walk out with a pump.
I’d like to add nitrous soon and I’m just scared of the idea of running out of fuel while I’m under boost.
The carb needs 6.5 PSI so I’ve been Looking at running maybe a Holley or Carter HV 110 ghp mechanical pump which will give about a constant 7PSI and maybe a 2-4 PSI electric “helper” near the tank. Still need to pick a fuel line size but thinking about 3/8” or 1/2”. I hate using HP numbers but aiming for approximately 650 ballpark revving up to 6,500
I know some guys run one on a stocker motor but has Anyone else run a helper on a HP/racing application?
Would I need to regulate the additional 2-4 PSI? Or will the mechanical pump internally regulate it?
