mopar4don
I am looking for the best way to go about installing this donor roof skin and appreciate your input.
Thank you
I patched the back rear window channel
I was planning on sanding the skin down to bear metal, then removing the skin.
Then rust converting both sides (inner and outer)
Then epoxy priming both sides
Then welding the skin onto the car
I am concerned about the skin warping on me, by creating to much heat when sanding using this style of stripper.
some pics of the donor roof skin,
and yes the donor skin came off of a vinyl top car but has very fine pitting which is why I plan on rust converting
Thank you
