When I wanted to learn to weld, my dad started me off with 7018, and told me, if I could learn to run this rod out of position, I could weld anything.
I was welding for 5+ years before I ever tried a mig, lol
A good tip for beginners to learn how to set voltage and wire speed correct, is make it sound like bacon sizzling in the pan, and your there.
Once you get some welding time in, you will know when it needs more of one and less of another.
One more thing you can check is the size of the wire, your running.
If your trying to weld sheet metal with .045 wire, it will be more difficult then .030, it takes more heat to melt the thicker wire.
