Cncguy1
I've been looking everywhere for these fan kits, every retailer says discontinued. Anyone know why? Maybe someone here has one they will sell me?
tonys parts have repops of those parts.I've been looking everywhere for these fan kits, every retailer says discontinued. Anyone know why? Maybe someone here has one they will sell me?
I have one that has been mounted but has not been run.I've been looking everywhere for these fan kits, every retailer says discontinued. Anyone know why? Maybe someone here has one they will sell me?
https://www.summitracing.com/parts/dcc-4120758/overview/
You need to know the clearance between the radiator and the WP. This unit is 3-1/4" tall. MP recommends 3/4" radiator to fan clearance.
PM if interested...
View attachment 432591 View attachment 432590
Sorry, already gone.Is it still available?
Can't you just use one from a JY 3.9/5.2/5.9?
The fan itself, yes, flip it around since the Magnum engines are reverse rotation. Install the fan on the thermostatic controller at the depth you need. Hayden sells them new in various lengths.
But if you take a box fan and rotate it 180 degrees it spins the other way and moves the same amount of air?The Fan's rotation and air flow cannot simply reversed or inverted
This is exactly right since the Magnum fan is a direct mirror of the older engines 5 blade viscous fan.But if you take a box fan and rotate it 180 degrees it spins the other way and moves the same amount of air?
