I see advantages to it, like no rusting or oxidation, because it eliminates water. Also a BIG difference is with the waterless Evans, the system isn't under constant fairly high pressure, and that has to have some benefits in reducing or eliminating wear, tear, and damage that would be pressure related.
Now I was concerned about it running warmer than a typical water/antifreeze based system, the cost, and the need for a very water free system for it to be introduced to.
On the subject of overheating, we picked up our 65 GTO today, that a "referred home based" mechanic has been working on for a couple of months. Dakota Digital VHX gauges, Wraptor serpentine belt and accessories system, and Vintage Air too.
One of the 2 Cold Case electric fans went out in their "2 fan and aluminum shroud" system they sold me. I can't blame the fan yet, but I don't know why it died, but it's definitely dead. I got the GTO radiator (and I bought one for my 440+6bbl Roadrunner to replace the 26" factory radiator) from Cold Case and once the Wraptor was installed, it pushed everything far enough forward towards the radiator that the factory mechanical fan and shroud had to be replaced.
There are a number of problems that unfortunately I didn't discover until (my wife) drove her GTO home, with me following.
Long story short, not only did one of the fans go out, but the DD water temperature gauge claimed it was running HOT, like WAY hot. I don't believe it, because at 295° the pressure relief spring in the cap on the radiator should have been forced up and open to relieve pressure, but that didn't happen. I think the temp gauge isn't programmed properly, and since we also RAN OUT OF GAS, I know the fuel gauge is NOT programmed correctly!
