Keep trying the same thing and expecting different results.
I built a 440 based 505 Stroker, It started fine, but during break in, a rocker adjuster loosened and the lifter popped out of its bore and spilt its guts. Replaced the lifter and completed break in. Then the starter broke. I figured that I forgot to tighten the mount bolts, so I replaced it.
Also, the torque converter (lock-up) was difficult to install and had no fore/aft movement with trans bolted to engine. I figured I’d run it a few miles and re-check it.
Started fine for a few times, but on a test drive, at low RPM it sounds like a tractor, and getting on it, it’s sluggish. And after a few more starts, the starter broke again.
When I checked the torque converter, it still didn’t have fore/aft movement. So I pulled it out and sent it back to the builder. They said the hub was welded on wrong, fixed it and sent it back. It went on smooth and easily this time. I figured the incorrectly positioned hub caused the starter to break, and re-installed everything.
Engine starts fine the first time, no noise or grinding, and then breaks on the second attempt. So now I think maybe something wrong with ring gear. So I buy another torque converter from another company, and when I remove the original one, everything seems fine with it.
So here I am today, trying to decide to install another mini starter, or a more robust stock starter. And I’m thinking maybe the cam timing isn’t right causing too much stress on the starter. BTW, I never degreed the cam. Compression check was @ 190 PSI in all cylinders
thoughts?
thoughts?
