SOLD T&D Machine Pinion Setup tool
Ben Mowery
4:05 AM
Indianapolis, Indiana
Feedback: 2 / 0 / 0
T&D Pinion Set Up tool 11001. Used one time on my axle setup. Save some $$ over new. $475 shipped in the 48. PayPal ok if you pay the fees.
183F55D2-08D7-4024-A5F4-F1FC7111545F.jpeg 2364E0CC-B325-4733-B322-DB337FFB7E56.jpeg 066ADC1C-956C-4F32-9360-E2716E179924.jpeg FD5D3731-2B98-41B3-ACAF-3CE49E66DF47.jpeg
Will it work on a Dana 70 and 80?
Off their webpage,
Designed to work on most popular Domestic differentials such as the GM 10 and 12 bolt, Ford 9", 7.5 8.8 and 8" most all Dana axles up to Dana 60, Chrysler 8.75.
I would have to call them to see. It works with a 60.
The tool I have bolts in but the 70's pinion depth is a lot different and mine won't cover it. The ring gear is larger in diameter than the 60....other than that, many of the other parts are the same like the majority of the bearings and even the Powr Lok clutches are too.
see below. T&D says yes if you buy another set of the hubs for the 70/80. They via the phone said they are $76.
That ain't right. The adapter hubs fit as the carrier bearings are the same between the two. It's the indicator plunger adapter that I would need to make mine work in a 70. Since the 70 has a larger ring gear, the pinion gear sits further away from the ring gear center line. Heck, even the rear cover from a 60 fits the 70.....
