SixBarrelBill
Hi everyone. I'm installing an air grabber on my 70 Roadrunner which is not an n96 car. I have the hole drilled, in what seems to be the factory location, and now I'm to the point where I need to drill the smaller holes to attach the switch to the metal dash.
I have not found any good reference as to which way the switch should be installed. I know there's an on and an off to this and I don't want to take a guess on drilling the holes for mounting.
On the back of the switch there are three vacuum ports, the vacuum port closest to the outside of the switch is my guide. Does that go on the left or right hand side of the car? Based on the little drawing that I have,
I would guess that third port would be on the right hand side?
Thanks for your help,Bill
