A good Flat black brand?
747mopar
3:33 AM
ohio
I've got a project going on that I want to use some flat black on but I'm half afraid to buy some, most aren't flat at all! What's a good brand of paint that makes a nice flat black, no shine?
SEM hot rod black.https://www.nationaltoolwarehouse.c...tm_campaign=NTW+-+Smart+Shopping+-+BOOST+Item
Believe it or not, your John Deere dealer has great flat, matte, and semi gloss paint.
Just use any good base coat clear coat and add flattening agent to the clear
U-Tec
you can choose the amount of flatness. 10-20% 20-30% 30-40% and so on.
No rattle can. Shoot with a gun.
Eastwood dead-rat flat. Its the flattest I have seen with any durability.
Rustoleum: Not really flat
Krylon Colormatch flat: Is very flat but not very durable.
Krylon Chalkboard paint: Very flat but again not durable.
Krylon Fusion Matte: definitely not flat.
Anything that says Rat-rod flat (duplicolor, etc.): not as flat as Eastwood dead-rat.
I find that flattening agents from paint mixers usually require buying alot for agent. Like a gallon at a time.
Good luck,
RGAZ
I agree with 1967Cornet. SEM Hot Rod Black. Not all that cheap but will last and is very easy to spray.
The U-Tec is a single stage Urethane. Much more durable than SEM, which I've used, and you can pick the sheen.
I've used SEM's Hot Rod black, I liked it but had different results the 2 times I used it... Maybe it was the temp, not shaken enough?? I liked it fine but the second time it wasn't very flat.
U-Tec
Agreed, I don't want any rattle can paint. Looking for a good Urethane, I'll check into the U-Tec when the time comes.
Thanks
Here's what I'm going for but on an 83 D250.
 The blue is coming along nicely.
