Two years ago I bought an MSD pro billet ready to run. I bought the whole shooting match wires, distributor, and coil. I installed this, the car would hardly run. Backfire, missing, and stalling. Called MSD help line, was told I had the firing order off or distributor in a few teeth off. Also said to run a ground directly to battery and a 12 volt wire from battery to coil. Well nothing worked. I called them back tech kept telling me it is a firing order issue. I explained how I can put the other distributor in and it runs fine. So I got an return authorization, sent it in 4 months later I get it back in the box was a typed note No problem found. Put it on shelf and forgot about it. Well installed it again runs like ****. I talked to the speed shop I bought it from said he can convert it to run with an ignition box. The guy at the speed shop said 10 years ago he could have gotten his rep to replace it but the company has changed and warranty is not what it used to be.
I would have not have thought about this but my ignition box failed tonight and I thought dam if that MSD wasn’t such a piece of **** I wouldn’t be having this issue!
Just wanting to vent
Thanks
Thanks
