Thanks again still working on shift pointsMine moves 1-1/8 from idle to WOT. I have it almost bottomed out at WOT. This means when I’m coming off idle the kickdown is at the same point you’re at when halfway into it. That’s where I started before drilling a hole closer to the throttle shaft. By doing that the throw is shorter and the kickdown is always more compressed. That’s actually close to factory. The aftermarket carbs mostly have the attachment hole farther from the pivot so you get less compression of the kickdown linkage.
Another thing of interest is that I don’t think the pedal can pull the cable that far. You might not even be hitting WOT. Might want to confirm.
How is it? Just curious. I have a Holley 3310-1 and CH4B on mine with the factory intake and 3644 (identical to 3611 but was used on 413s) sitting on a shelf. Kinda wonder what the performance hit is like.Well it's been almost a full year since the last post on this topic. Since that time I have returned completely stock with original intake and 3611 AFB.
Headers work wonders. Don’t feel too bad about the ‘64 manifolds vs the later magnum. Here’s an A - B dyno test between the two, 4HP! And -1 ft-lb! They both aren’t great.The potential is there of course...you just need to change a lot to unleash it. It loved that intake and carb but without better flowing exhaust manifolds its a dead end.
