Drew67coronet
Hello all, I'm back again with another problem. Ive got a bone stock 1967 273 2 barrel engine with a single points distributor With my vac advance hooked up my engine stumbles all the way up until I give it a good amount of gas then it runs like a raped ape.
If I unhook my vac advance the stumble disappeares. I tried to remedy the stumble by advancing the timing and that worked great but caused the engine to ping at all RPMs.
So no good there. I retarded the timing back to where I had it. And it runs great Im just wondering if maybe I need to adjust the timing more? My vac advance canister is not adjustable.
Thanks
Drew67coronet
Thanks
Drew67coronet
