Donny Cloak, I.m trying to hit the nail on the head, 64 65 Hemi Sat with a custom paint job..
The Red Cabin was a real good hangout for fast times, cars ,women,n what ever clocker was dealing,he knew his mopars n was into a lot of ****,i think he did some time in crowbar hotel for a while.Did you know a John Larrett he owned the 69 cuda,this would of been the late 70 to 83,he also owned a 68 black R/T charger 4 spd n traded it to do the tube work on the cudathink you covered most bases except PI on the queensway which was a few year later and woods had moved up near the airport!
i grenaded my 383 right in front of cloaks shop making a pass over the Bridge. His shop was strategically placed down from the light before the bridge I would be topping out second gear right there.
Red Cabin beside cloaks, Rod's Hangout [harveys on the queensway] and Golden Burger [across from apache}
yep i do the room is where the walk in door is. Its about double the size of the furnace. I was thinking of putting a hole in the wall & ducting air from outside along with a filter.Combustion air, the air required for the process of combustion, combustion air for a standard or mid efficiency furnace comes from inside the building, high eff furnaces, infrared tube heaters ans sealed combustion heaters take combustion air from outside. Two different animals all together. So,if you have a standard eff oil furnace in you building, you need to think outside the box , xman, you said your furnace was in a separate room than you shop, if so, is there a window in that room, if not, could you install one. If you kept the furnace room closed, sealed from the shop, opened the window in the furnace room you could feed that furnace clean combustion air. Understand where I'm going with this?
I have to prime a hood this afternoon, my roll up door will be open 10 feet x 1 foot, for combustion air, I may even drag a salamander down from the barn, and run it inside the shop, to keep my shop temp over 21c.
hijack, i guess we did. shouldn't the airflow be reduced to nil painting when your not in a designed booth to allow the overspray to drop and not spread throughout the rest of the shop and having an airhandler moving dust around just doesn't sound right to me. I'd just shut the furnace down until the paint has hit the floor.
