So, I've been researching around a bit to try to figure out why Mopar did or didn't use fan shrouds and what were the deciding factors as to which cars got them and which cars didn't. I'm specifically trying to figure out the 1970 models because that's what I'm working on right now. One member that has done a good amount of research on 1970 B bodies, and is very knowledgeable on them, told me that the fan shrouds were dependant on axle packages, A31-A36 and if the car was an axle package car it would have a fan shroud on it. I believe that would also dictate a 26" radiator, correct? So was it a 26" radiator that dictated a fan shroud and the 22" radiator didn't get one? There is no factory option for a fan shroud so they must be mandated as part of a package. I have also been told that by 1970 Mopar used fan shrouds on everything and also that all GTX's had one installed. There's some pretty sharp people on this forum so I wanted to throw this out here for discussion in the hopes that I may learn a bit more about subject.
