69 Charger Mark
What is the correct wood grain steering wheel for a 69 Charger. I see some where the 3 spokes look more like a "Y" and other that are more flat and look like a "T". Thanks in advance.
Yes the 70 model has three holes for the column adapter ring. Other than that they will interchange with no issues. I have seen different color wood grain between the 68/69 and 70 models, where the 70 was a lighter color grain. I have not seen or heard of different spoke placement as mentioned above.There is difference between 68/69 ....and 70 ... center has more holes drilled into it
I don't think so. It looks like the first wheel is pictured straight on and the bottom picture is at a slight angle from the bottom looking up. The spokes and the holes in the hub are at the same places between the two wheels.Step back from the screen and look, there are two different wheels in that picture. The clocking of the spokes is different.
