dsd1967
I have a 1978 big block 727 that came out of a class A motor home. It has the short tailshaft housing with a drum brake on it. The transmission only has 285 miles on it (there's a story behind that), so I would like to use the transmission.
The issue is that I need the standard car/truck tailshaft. I had a 727 that I scrapped several years back and in the process kept the tailshaft and output shaft. Problem is that I don't know the year or application of that transmission.
My question is.....am I that lucky that the output shafts were the same throughout the years and applications....or am I going to run into an issue on splines or something like that. What would I need to look for? Any help would be appreciated.
Thanks
Dave
Thanks
Dave
