- 5:41 AM
- Dec 3, 2020
- western Maryland
So, the previous owner wired in a dixie horn setup with some....hillbilly-level wiring (and I'll leave it at that). I've downloaded and printed out the wiring diagram, and I've done quite a bit of wiring in my life so I have no problem reading it...but I'll be damned if I can find what these wires are. And I'm going crosseyed, so I figured I'd ask the pros.
There's a small bundle, under the dash, in the area of the parking brake release. This is what they hacked into for their horn relay and its own pushbutton under the dash. I have:
black with a red tracer
dark blue with a yellow (maybe light green - it's pretty filthy) tracer
light green
light green
and, spliced together into a factory rubber splice with what looks like a ground-screw loop, a pair of dark blue with white tracers (these are heavier gauge than the others).
The diagram shows a horn relay that should have:
2x black with tracer (but what color? the diagram just says "black-tr")
dark green with red tracer
Where, physically, is the horn relay supposed to be? Did they hack into what used to be the horn relay?
Other electrical issues I'm trying to solve are, no gauge lights (headlights, taillights, high beams, and turn signals all work outside the car, but no gauge lights).
Right turn indicator on the dash does not work (left, and high beam, indicators do work)
Things that DO work:
Key buzzer
both door switches
dome light
console light-package lights
glove box light
horns themselves (I unbolted them and fed them voltage on their own, and they do honk)
I didn't want to go hooking those blue/white trace wires to ground if they're supposed to be hot...but damned if they don't show signs of a bolt through the ring.
Are the light greens supposed to be connected to each other as well? They're not yellow - they look like hi-viz construction vest color. I also see some other wires that are yellow, so I think these are going to be called out as light green. I could be wrong.
I'll keep poring over the diagram, but the next question is...how the HELL do you get the cluster out? I have it loose, and can almost get it out, but the bottom right corner gets caught on the a/c vent surround. Does the knee bolster piece need to come off? Or do I just keep wiggling the left side out at an angle, hoping there's enough wiring slack? How do you get that knee bolster off the dash skeleton? Clips? I didn't feel any nuts on the backside... I've lowered the column so it's out of the way, but I want the gauges out so a) I can test switches, dimmers, bulbs, and voltages, and b) so I can have access to stuff and look around better.
Thank you for any pointers - I've had the car 2 weeks and I'm trying to keep making progress so it can hit the shows in '21....and so I can drive it and enjoy it!! Right now, though, I'm going to take some ibuprofen for my back spasms, and dig through that diagram some more.
light green
light green
Key buzzer
both door switches
dome light
glove box light
