hey guys is the right front brake line 5 1/6 if it matters it is disk brake, i have to scramble to get it, we in ontario canada are going throw a lock down again. thanks.
I usually measure approx. how long a piece I need an buy the closest size of that new (copper impregnated) brake line that I can get. Usually the correct size fittings are already on it and it bends so easy, (no tubing bender required! Take a quick measurement of the fitting size at each end and or just buy a couple different size adapters; plugs and connectors to make it work. I always keep a few pieces of line and adapters in stock as they are not expensive! Every car I ever had,(all Mopars), had 3/16" line. I also use the stuff for fuel line. If it is the rubber line you are needing, they will look up your car in the book or you can remove the old piece, plug the line, and bring it with you to the parts store. I usually cut the line close to the fitting and remove with 6 point sockets. Best of luck, I just helped my neighbor replace rotted lines on his old truck a week ago!
