383man
A few weeks ago I was checking my headlites on my 63 Sport Fury and I realized my inner ones were not working on high. So both had power and ground and I replaced both inners and they lite now. But I checked my voltage at the headlites and found only about 13.1 volts with the car running when the hot post on my firewall from my battery in the trunk was at 14.5 so I have over 1 volt of drop at the lites. Well from working at a Dodge dealer for 24 years I have saved a few relays and decided to go and wire my headlites to relays. So I cut the harness open near the rad on the inner driver fenderwell where it goes out to the lites and I tapped and soldered the wires in there to my two relays for low and high. I ran grounds for the relays and took my hot feeds off my hot post on my firewall which I fused. And they work great and even look brighter with no voltage drop now. I should have done it years ago and took the load off my 50 plus year old headlite switch. Ron
