SattyNoCar
- 6:50 AM
- Dec 13, 2013
- Between Houston and Galveston TX
Last time I asked this question (on another site) almost 20 yrs ago, I basically ended up with a bunch of 'I have a friend who knows someone'........... no actual shops,
Is it still the same way now? Or would I be better off shipping the engine out to someone?
Not looking for anything radical, I am wanting the 400 that originally was in my wagon rebuilt. I'm looking for longevity, not 5 second quarter mile times. I plan on taking road trips with this car.
Engine has about 54K miles on it, but the miles are low because it spun a rod bearing. Previous owner yard drove the car with the spun bearing apparently quite a bit because you can measure the groove wore into the crank with a tape measure.
I have a different (used) crank, and someone gave me (stock) rods from a similar year 400. The rod with the spun bearing had enough play that the piston met the head a few times, but, I was able to take the heads and use them as is on another engine.
Unfortunately, I didn't do a good job storing the block, so everything has a light coat of rust on it now.
I've never rebuilt an engine myself, so, aside from lack of experience, I lack the proper tools too. At this point, would rather let someone else handle the work.
Suggestions or even comments in general?
John
John
