Gauge Cluster issues
Bruce Meyer
1:13 AM
Palm Desert, CA
Just finished installing new gauge cluster, Speedo, Tic Toc Tac, Fuel, Temp and Oil on my 70 Roadrunner 383. Also installed new circuit board, light bulbs and low voltage limiter. All seemed to be fine at startup. Good oil pressure, fuel gauge reading well and temp gauge working fine. Until I started driving bout 5 miles.
Then.... in perfect unison the fuel, temp and oil pressure gauges started moving to the left ever so slowly until they "zeroed" out. Then they started to reverse course, again very slowly then back to zero again. Always in complete unison.
Any suggestions would be helpful. Ground issue? Low voltage limiter? Power issues at the gauge pin connector? Thanks.
try and put the old limiter back in and see what happens. Just saying the OE limiter has been around for 50 plus years in many cars and still work.
So do you think this in "Unison" gauge movement is a voltage drop issue?
I was gonna comment on George Custer......but then i read it again. Time to get my eyes checked again, i guess.
Well they all have separate grounds, only thing common is voltage from the limiter. I'd look there 1st
I ran a wire connector directly from the voltage limiter ground to chassis ground to be safe when I initially installed it. I'll try putting the original limiter in.
Well, after pulling the cluster out again, I replaced the new voltage limiter with the 50 year old one I saved. The old Bird loved the old one much better. No issues with the "moving" gauges. Just goes to show you older can be better.
there is a video on how to check if voltage limiter works. google how to test chrysler voltage limiter very ez to do.
A lot of talk about grounding the speedometer/gauge/cluster. When I first took mine out, it wasn't grounded; so my question is, just where do I put the ground wire on the gauge? I installed a new circuit board that has a built in voltage limiter because the fuel and temp gauge didn't work. They still don't work. Both Fuel and Temp bench tested o.k.. Some help would be greatly appriciated.
I've bench tested both the fuel and temp gauge; both work. Ohm tested the wires going to both and they both ohm tested out. After having trouble with several OEM voltage limiters, I bought a (non-rally) curcuit board with a built in solid state limiter from Vans Auto. All the dash lights, turn signals, and oil light work; but the fuel and temp gauges don't move. Gage cluster housing is grounded. Is there something else I need to do?
