Help settle a bet
Not quite that advanced yet. I do have a similar device for dent pulling. You weld the tip to the dent where you want to pull and there is a slide hammer on the rod. You pull the dent and then break off the weld.
Yup. Those work well. I just bought one for aluminum theres a process that takes getting use too.
'67 was still screws i know....'68 i dont know. You need to find an old TRW man (Nelson Stud Division).
never seen a gm style stud on a 68, or a 69. or a 70.... anywhere......
In restoring an early '69 Road Runner (build date Sept 30, 1968) I was advised that the rear window had clips complete with screws but that there is no rear window gasket available.
there wasn’t a gasket per say on the 68-70 b body cars. 3m butyl rope (comes on a roll) was used for the seal along with a couple rubber blocks that go between the channel and glass at the bottom to keep the glass from settling down. Most find that the 5/16” diameter works well but also available was 3/8” diameter.
This is from the 1968 Plymouth FSM, I would imagine Dodge to be the same.
