I take for granted everyone doesn't know this. If you're having trouble soldering with a soldering iron, use a wet sponge or rag to wipe it when hot. It'll remove all the crud and make soldering much easier.
I won't give you the red X, but you should be using a rosin core solder for electrical work, and therefore do not need flux.Also paste flux is your friend.
Never use it I use silver solder only, old USAF habit I guess and rosin core can also add corrosion to a joint unless cleaned with denature alcohol afterwards.I won't give you the red X, but you should be using a rosin core solder for electrical work, and therefore do not need flux.
I/we used to use leadfree solder for RoS compliance, and what a bitch to melt with air, 425 degree C IIRC!! I stayed with lead solder for R&D work, Hot air gun, and surface mount components (0502 on average).Never use it I use silver solder only, old USAF habit I guess and rosin core can also add corrosion to a joint unless cleaned with denature alcohol afterwards.
Nice soldering station.No, a hot air soldering station for electronics. The surface mount components were so small, that is the easiest way to do it. Average components I worked with were 0603, 0402, and 0201 which is a designation for the size of the component, (0.063"x0.031", 0.039"x0.020", and 0.024"x0.012" respectively.
It most definitely was. When I went there (Skycross), they used two Weller pencil tip irons like chopsticks. I said I don't do Chineese, so if you want a pro job, get me this, I had it in about a week...Nice soldering station.
