Can 66 Sat top of fender trim split be aluminum welded?
I'd be interested if it works on 55 year old aluminum.
I'm a skeptic but who knows? Worth a try
I’ve seen that demonstrated at gun shows too - although it’s been awhile. I might try to track it down and try it on a piece of scrap aluminum trim I have.
After doing a little research it appears these low temp aluminum repair rods have a high zinc content and probably would not take well to re-anodizing where exposed. Decided to not go down that path for right now.
Dang - looking at the other side and it’s split right at the turn signal light too - just like the other side . The splits are so tight you can feel them more than see them. I may just carefully remove them and apply JB Weld to the back side to hold the tightly together.
Should check if there's a why they split. A little fiberglass to reinforce the JB?
So, you need both fender mldgs ? I can ask the man who I bought my car from and see if he has any spares
Im looking for an NOS pass door mldg if you hear of one.
I would appreciate your asking. I have a bunch of various trim up in the attic left over from my 67 GTX scrounging junkyards days. Probably a lot of other owners do to.
I just put a call into him to see if he has anything. When he did my car he used all NOS except for the pass side door. that one he had to use a REALLY nice used due to unable to find an nos one
Should here back next day or 2
PM sent with contact info/
he said he thinks he has them
Bill
