I apologize, I meant to include the following, Call Joe Suchey, he’s knowledgeable, sells a ton of parts for early b bodies, and one of the nicest fellows on the planet ....
From what I remember the inner & outer were the same, however, my parts book says they are different. I’m looking further in my parts info....
I will also get the number for a company who sells this in bulk, or they used to. I was also thinking the 330 I owned in the early 90’s had the gray/brown cloth cover on these pieces. I looked on my parts book, but it just lists part numbers, per body style, no additional info on the actual material. Hang in there, I will post information that hopefully helps a bit more the next day or two.
The 63-65 B-Body four door sedans and wagons use the same felts and are available as a quality reproduction piece. The 63 to 64 four door hardtop B-bodies are unique to themselves. They will be a combination of flocked rubber pieces and whisker materials.
