not so famous bob
need a single from a broken set --------------
How about a semi melted one? It's not warped but got REALLY HOT at some point. The lettering is kind of squiggly.
I have one Mopar Performance that had a broken right bottom ear, then welded. Cosmetically looks good. Could probably be fixed. I couldn't get it to stop leaking.
What side do you need
I have one that got cracked across the top corner. Somebody modified the opposite corner to clear one of those crazy oversized distributors.need a single from a broken set --------------
I wouldn’t consider it good for much other than experimentation but there she is.
View attachment 1064393 View attachment 1064394 View attachment 1064397
No problem. It'll probably wind up at the scrap yard the next time I take some stuff there. It's aluminum after all...Crack is down to far , thanks anyway !
I f it was in the top ,would be no problem---------
