s5757s
- 12:36 PM
- Mar 29, 2014
- Battle Ground, WA 98604
What thread size of stud do I need for mounting my mechanical fan blade to the water pump flange ? Is there a kit available ?
Using a 2.375 long aluminum fan spacer, steel fan blade is .25 thick & water pump flange .5 thick so I'm assuming around 4" long ?
I see GM kits which are 5/16" coarse x fine thread studs. Mopar BB440 the same ?
Thanks,
Thanks,
