Danny Boy
Secret of life is enjoying the passage of time JT
- 11:56 PM
- Mar 13, 2018
- Land of Enchantment
Thanks in advance for your comments as I'm trying to get educated before plunging into working on my 8 3/4
1. In process of converting 741 from open to Sure Grip.
Will be keeping same 323 gears and only want to convert to Sure Grip.
What is required to perform this conversion besides purchasing the Sure Grip and it's bearings?
Hopefully it's a DYI and won't required many tools/effort necessary as when changing ring & pinion
2. Here's a link from Cass at Dr. Diff regarding ring/pinion install
https://www.pirate4x4.com/d1/tech/b...Ring and Pinion installation instructions.pdf
3. Also, saw this on Ebay and have a question regarding the mesh pattern.
Maybe I'm not seeing correctly but it appears that there is no mesh pattern - looks like face of tooth has been wiped clean. Please help me as I don't get it...
Is this an acceptable pattern? (or lack of)
