- 6:01 PM
- Apr 13, 2012
- Granite Bay CA
I may have it figured out with these suggestions from FBBO guys. Thank you.
I fall victim to my temper and I don't like to lose to any person or any thing. I often forge ahead to get things done but I was on the verge of taking a hammer to something.
I measured the clutch alignment tool. It fit in the pilot bearing with a very slight wiggle. I count this a .625.
I got the trans out and measured the input shaft. I see this as .685. The input shaft IS larger than the pilot tool....
I checked again to make sure the bell slipped over the bearing collar of the trans. Yeah, it fits fine. It doesn't slip on though, I had to tap it with the rubber mallet.
The clutch fits the splines just fine.
