The vinyl parts are warped from the Tucson heat. Deal with it, or find replacements on ebay. You might get lucky, but I don't think that stuff is reproduced.
The dash is just sitting there with no attach hardware. It goes flush when the screws are installed. What are those vinyl pads mounted to the dash frame called?
Kinda depends on what your trying to achieve... Nice used pads are getting hard to find so you probably won't save much... The repo pads probably will look better than 90% of the used pads your gonna find, but over $600 by the time they are shipped would make my cheap self want to at least look around for decent used stuff
Try Ditzer vinyl conditioner. Soak a small towel the size of damaged area. Put towel against damage area and cover with plastic wrap. Check every 4 hour to see how it's working. Might take a day or two? May not work or be short lived.
I'm not a big e bay guy but I did some looking last night and didn't find very much for used stuff. At the end of the day about a difference of a hundred dollars, two hundred at the most. And like Fran said will have to make some repair and most likely dye to correct color. I'm leaning towards the new stuff.
You may be better off with re-pros but my dash has A/C and as far as I know, no one is re-producing the center duct piece or the slider ash tray pad. I sent mine to Just Dashes. They did a nice job but they don't put the stitching in like the originals. Not sure if PG Classics does either. Here are some pics of mine before and after. About $900.00 back in 2014 for the 4 pieces.
I bit the bullet and sprung for the repros from PG classics. I was able to get a 10% off code but the shipping just happened to be almost the exact same amount, a difference of fifty cents. Go figure. I would expect them next week. I'll report on fit and finish when they are installed
Frank
That is not uncommon for where you live, we deal with it here in New Mexico also. Always had to by good used from back east. I think Classic sells them now also.
