Hijinx
I need help installing dual spal fans onto the Holley Sniper EFI system. I purchased 2x Mr Gasket Relays PN #40100G. From what I am able to understand…
1. I need to connect the sniper light blue wire to pin 85 on one relay & the sniper light green wire to pin #85 on the second relay.
2. Pin 86 on both relays go to the battery +
3. Pin 87 on 1 relay goes to Fan 1, pin 87 on the second relay goes to Fan 2. Both grounds on the fan pigtails go to battery ground.
4. Pin 30 & Pin 87A are un-used…
Is this all correct? Or does Pin 30 go somewhere?
