junkyard junky
Pulled the poly 318 engine from from 65 coronet. Replaced it with a 87 Diplomat 318. Outlet on the water pump is on the passenger side. Was wondering if I could put the 65 pump onto the 87 engine? Thanks!
I believe you are correct. Timing marks on my POLY are on the left (looking at the front of the engine). If memory serves, most LA engines are on the right.The timing cover and balancer will have to be changed also from the poly.The change came in 1970 with the aluminum water pump.
