Going through all the wiring on my car and replacing some of the harnesses and finding a few uncertainties along the way.
Can anyone identify for me where the factory tach wire penetrated the firewall? From all the wiring diagrams I've looked at, it wasn't a bulkhead connection. However someone had drilled a vacant terminal space on on of my bulkhead plugs and run it through there - an incorrect route I'm pretty sure.
Also, where is the engine to body ground strap supposed to be run? This car has a hemi engine and I've been over and under it a lot but haven't actually found a ground strap from the engine to the frame/body - unless it's wrapped in with the starter harness. Engine compartment is so crowded by the engine it's hard to look everywhere behind it.
Thanks
Thanks
