Dibbons
- 2:14 PM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
I need to do this pretty soon.
Yesirree. That would not go well.Just take an old lifter apart and mix up some Epoxy and fill-er-up. wait till
it cures and you're good to go. I've done this in the past but make sure
you mark it so you know not to use it for a good one. Ha!
Don't really see the point in going thru all of that If you are not going with large oversize valves, a huge lift cam, or large domed pistons. His looked like flat tops or dished to me.
Anyway, either just:
THIS 》》1) Buy a solid lifter to use for checking
2) Replace a valve spring with a light checking spring that won't overpower the lifter internal spring
