65_Satellite
I searched the forums but didn't seem to find what I was looking for. I recently converted my 65 Satellite to front discs and swapped out the old single reservoir to a dual reservoir. I bought the whole kit including the master from The Right Stuff. I also purchase the full steel brake line kit from Inline Tube including the new hard lines from the master to the dist block. My problem is this: The rear hard line screwed into the master with no problem. The front one, however, only went in about halfway and got really tight but I can still move the line in and out cause its not seated properly. I dont want to force the fitting any tighter for fear of stripping out the master. Is there an adapter I need to put in the master before the steel line? Any suggestions would be super helpful.
