64SF
I've installed an aftermarket mechanical speedometer in my 65 Satellite. It's a 4 speed Transmission with the flanged output shaft. The speedometer cable is part of the speedometer gear (I hope I'm describing that correctly) it is not like the 66 and later transmissions where the cable attaches externally. Here's the problem...the new speedometer will not register above 20 miles per hour. I'm wondering if cable inside the jacket may have failed or may not be going into the speedometer all the way. If the cable has failed is it possible just to replace the internal cable (inside the jacket) or must I buy a whole new one which over $120.00. Any thoughts or comments appreciated. Thanks
