- 4:34 PM
- Mar 28, 2014
- South Louisiana
GET SOME!!
I did....what any dedicated racer in a state of frustration would do: threw more cash at it.
Not that this thread needs to drag on forever, but I figured I’d update:
We didn’t learn anything last time out. The car wouldn't make a full pass due to fuel issues; it would massively flood itself when I mashed the throttle. We Pulled the needle & seat to find it clogged with rubber probably from the cell installation. Thought we had it figured out, but it continued to do the same thing. Pulled the entire carb apart all looked well, but the problem persisted nonetheless. I then put a regulator on it to make sure The mechanical pump wasn’t just blowing through it, fuel pressure steadied out some, but no changes in the problem.
So I drug the car home and did what any dedicated racer in a state of frustration would do: threw more cash at it. If you’ve followed this thread, you know there’s been no shortage of that this winter for me. Anyway, I’ve ordered a whole new, MUCH better thought out delivery system that includes an Aeromotive pump, billet regulator, return line, and dual filters - 100m pre and 10m post pump. The only thing left to consider in the carb is the power valves. Holleys got them front & back in my annular 1000 4150. Considering it’s flooding when the throttle is chopped open, it certainly could be something in that circuit. I’ll replace the front and plug & rejet the rear to simplify things. At that point, the whole system will be redone and should be able to handle considerable growth when called for.
I’ll report back when things become more clear.
—-Well, although I am yet to get the intake swapped over (existing RPM to an M1), I made some solid passes today and I think the changes are in the books. A few weeks ago I was handed a time slip that said 10.87. The incrementals just didn’t add up and I didn’t know what to think. Well, we saw some solid passes today and will chalk the 10 second time slip up to timing system error. With that said, the car went back to back new bests today @ 11.107 & 11.104. MPH was also a new best at 119.9 (knocking on the 120MPH door!!!). The short time on the slip was also a new best at 1.52.
thanks to all that have followed along with me this past off season here. It was a lot of work, but I’m happy with the results.
If you go with the M1 is there going to be hood clearance issues?
LW what converter are you running?
—-Its a Lupo / Dynamic 9-1/2”.
Perhaps your consistent 10 second time slips are only one 8” converter away.
i doubt it , depending on stall . Really just some more HP .—-
—-If and when I ever do a refresh on the bullet, I would go with more camshaft and at the very least have my converter loosened up a bit. I’d probably at that time just send it back to Dynamic and have them adjust it for the combo update.
—-I’ve considered a low-gear set for my 727. My theory is that a heavy, relatively low powered car may be the right place for that modification. Pretty spendy, but it could be right for my combo (??).
