Anyone have this stuff in their attics and notice a difference in cooling/heating costs? Many of the products
advertises up to 50% HVAC duct and HVAC system efficiency and yada yada yada. Time to find out if it's worth even messing with. One company is advertising a paint for the areas where you can't install the barrier like in a cathedral ceiling where the rafters are the ceiling support....
claims are just that a claim…
It’s like the weather ,.,
50% Sunny
Or…
50% Partly Cloudy
Pick one… simple …
But …
Radiant Barrier Tech .
Is 100% On The Munny Hunny!
Do The Math yourself…
Anytime You Can Reflect Part
Of the Radiant Gain into you’re attic it Pays Dividends !!!
Living in the Desert where 120
Degrees is Common … yep !
And…
The UV can give you a sunburn in less than 15 minutes !
Yep !!
Many Builders Do Exactly That
As part of the energy efficiency packages , makes perfect sense !
PS
Don’t you use the best lubricants
In your HotRod ?????
Really !
You mean you don’t take it to
IFFY LUBE when U need an oil
change ????
Get the drift !
Ultimately do What U Want !
Mopar2ya!!!
John
