joeb73
- 8:23 AM
- Apr 28, 2021
- Machesney Park ,Illinois
1969 gtx 440 Car was setting for along time. Replaced fuel tank, fuel sender, rubber lines, vapor sepotator, rubber lines fuel pump. Used vacuum pump to check for cloggged fuel line. All steel lines look good no rust. Still no fuel to carb. Any other ideas beside the pump push for. Or bad new pump. If the rod what is the length supposed to be?
