Does your car happen to be from California originally? I believe that green gizmo may be an emissions device. Remove / bypass it. The vacuum hose from the distributor advance should be connected to the vacuum tap on the right front of the rear carburetor. I will see later today if I can find the green gizmo in the parts book, but I only have 1969 version.
