steve from staten island
- 10:01 AM
- Sep 24, 2012
- staten island,ny
I was having a issue with trans popping out of forth on deceleration...Tired everything and to no avail. Spoke to Dan as I bought the parts to rebuild the trans as well as parts to convert my car to a 4 speed
Dan suggested I take the stops off the shifter and remove the console to make sure nothing was hitting shifter handle
Problem solved
I had installed a rubber boot over the rug into the tunnel hump and than the console and rubber that goes on top
Do I need the rubber boot below the console ????
I didnt see any interference with shifter handle hitting anything
I really gave the car a good run, took it out on the highway up to 70 and kept backing off gas and goosing it. Never popped out of gear, shifted good
Im happy to not have to remove that trans as removal was next.
Dan is a good guy, spoke to me at length
My rebuilder of trans is also a good mechanic, used all the right stuff according to Dan
Thanks to both these guys
Problem solved
