66Satellite47
That's not a standard OEM pan depth for a 727 or at least the vast majority of 727's.It's a standard depth pan, no filter extension for filter.
I would have to disagree with much of this; more fluid allows for more heat exchange and if you keep the fluid level where it is supposed to be, it will not uncover the pickup any more than the standard one. Deep pans have been available for a very long time and used is many forms of auto sports not to mention most modern transmissions come with deeper pans. Not trying to start any argument, just saying that deep pans have benefits.
If it's deeper than standard 3/8" at most, MO. Looked at that picture again it does look deeper but think its the picture. I posted a picture of mine post #8.That's not a standard OEM pan depth for a 727 or at least the vast majority of 727's.
What the H was I thinking says right in the ad 2.75" deep, my bad.IMHO, More room for slosh, uncovering the suction.
That thing's a BEAST!This thread peaked my interest so I bought this badboy to try out. I like the solid rails that theoretically should seal more evenly than the stamped pan.
How has this B&M pan worked out for you? Are you happy with it?It's in and ready for driving.
If you use this gasket, there is a like one for the 904 series, with a steel pan you must also use a bolt thats like two threads longer. When these gaskets were introduced, Mopar had a number for the longer bolts. If you didn't use them, it made stripping holes in the case easier. Check with your local dealer to get the bolts. On a cast pan these bolts won't work as they won't be long enough due to the thicker pan rail and you must source accordingly.for a pan gasket this is the best I've used
Mopar 727 transmission pan gasket 2464324ac and it is reusable to.
I ordered one of these TCI cast aluminum pans today. Should be here by Friday. My stock pan is now leaking almost as badly as the steering gearbox was when I first got my car..I have used this pan with no regrets;
https://www.tciauto.com/727-cast-aluminum-deep-pan.html
I bought this Moroso unit and their 93110 gasket. I must've gotten it on sale because I definitely didn't spend $250.
It is a nice piece with a rigid flange, good reviews. I just got the trans back in the car and haven't loaded it with fluid yet, so no personal experience there.
https://www.jegs.com/i/Moroso/710/42080/10002/-1
I had the same issue. I ended up use a mahle cork gasket with a metal carrier and put a thin coat of avaition form a gasket on both sides for the gasket and not one drop yet. Permatex 80019 Aviation Form-A-Gasket No. 3 Sealant, 4 oz. https://www.amazon.com/dp/B000HBM3QQ/ref=cm_sw_r_cp_api_glt_fabc_80SFJZ1Y6AN0PJDM91H6I tried a bunch of things and my pan is still leaking. This is beyond frustrating. I wont give up though.
My stock pan is leaking badly now. All the bolts feel very tight, so they have all probably been over torqued by a previous owner. I also suspect the gasket and filter haven’t been changed in 20 years..
