64SF
I'm still wrestling with a suspension issue on my 65 Satellite. As posted in a previous thread I can't maintain the ride height adjustment. After adjustment the right side "sags" or lowers itself almost to the bump stop no matter how much I adjust the bolt. The torsion bar cross member is solid, I've replace all the front end bushings. Could it be that I have the "same side" torsion bars in the car (they were in the car when I bought it). I found a torsion bar chart which seems to indicate that it may be a possibility. Below are photos of the numbers on the end of the bars....the 777 number is on both bars (last three digits of the part numbers posted on the chart) should I have a 776 and a 777? Appreciate any and all comments.
